Have anybody used these Monroe shocks before for sagging leafs?
Suspension, Steering and Chassis
  1. dustyaman
    dustyaman Well-Known Member
    108
    32
    Apr 23, 2012
    conway ar
    Local Time:
    8:56 AM
    And if so did they work well. 100 bucks for a pair is not bad especially for a known company.
  2. krazykuda
    krazykuda Well-Known Member FABO Gold Member How-To Section Editor
    62,854
    29759
    Aug 20, 2007
    Orland Park, IL
    Local Time:
    8:56 AM
    Band aids...
    Get new springs...
    • Agree Agree x 2
    • Like Like x 1
    • dustyaman
      108
      32
      Apr 23, 2012
      conway ar
      Local Time:
      8:56 AM
      I don’t want to get springs just yet because I’m still running a 7.25 rear. And eventually when I upgrade to a 8.25 I want to put all new springs and goodies in the back. Right now my car squats pretty hard.
      • Agree Agree x 1
      • SGBARRACUDA
        SGBARRACUDA ROY FABO Gold Member Legendary Member
        22,010
        10535
        Dec 7, 2006
        PLANT CITY FL.
        Local Time:
        9:56 AM
        Use to be called load levelers.
        • Agree Agree x 2
        • krazykuda
          62,854
          29759
          Aug 20, 2007
          Orland Park, IL
          Local Time:
          8:56 AM
          You can still change the springs with the 7 1/4" axle...
          Then you would just need the larger u-bolts when you upgrade to the 8 1/4" axle...
          • Agree Agree x 1
          • doug 371
            doug 371 Well-Known Member
            2,391
            697
            May 29, 2004
            Regina, SK CANADA
            Local Time:
            2:56 PM
            yes and then we would add the shock extenders for another 2" lol
            • Like Like x 1
            • Professor Fate
              Professor Fate Push the button, Max...
              3,743
              5553
              Jan 13, 2020
              Wisconsin
              Local Time:
              8:56 AM
              The springs don't care which rear end is mounted to them. Replace them now, your future 8 1/4, shock plates and u bolts will fit just fine when you get them. Trying to raise your rear with overload shocks (or air shocks) just puts excessive stress on your upper shock mounts, and can ultimately cause issues there- they're not intended nor designed to bear the weight of the car. They also usually require beating the seam of your fuel tank flat for clearance of their oversize diameter.
              Just get the springs- you know you need them anyways.
              • Agree Agree x 3
              • Bodyperson
                Bodyperson Pedal to the metal FABO Gold Member
                7,631
                10968
                Nov 26, 2015
                NW MONTANA
                Local Time:
                7:56 AM
                Seen a few shock mounts beat out of the floor.
                • Agree Agree x 4
                • Syleng1
                  Syleng1 Karma is real and Life is short... FABO Gold Member
                  2,566
                  2270
                  Jul 5, 2005
                  North Franklin, CT
                  Local Time:
                  9:56 AM
                  Yup! Tried them before.
                  Super bouncy, never sat even left to right and did not cure all the issues of 50 year old springs and worn out attaching points.
                  • Agree Agree x 1
                  • RustyRatRod
                    RustyRatRod I was born on a Monday. Not last Monday. FABO Gold Member
                    88,171
                    71263
                    Jun 7, 2010
                    Georgia
                    Local Time:
                    9:56 AM
                    The shock mounts are not meant to support any weight at all. This is why on a lot of cars that had either the load levelers you've pictured or air shocks often times have the top shock mounts torn out. They aren't made to support weight. New springs are the correct fix.
                  • dartfreak75
                    dartfreak75 Restore it, Dont part it! FABO Gold Member
                    11,416
                    9084
                    Aug 10, 2011
                    Virginia
                    Local Time:
                    9:56 AM
                    • Like Like x 2
                    • dustyaman
                      108
                      32
                      Apr 23, 2012
                      conway ar
                      Local Time:
                      8:56 AM
                      Thank you guys for all your input. I’ve decided to get the springs first. And some kyb shocks also.
                      • Agree Agree x 1
                      • TF360
                        TF360 Well-Known Member
                        2,134
                        823
                        Apr 25, 2014
                        Florida
                        Local Time:
                        9:56 AM
                        They don't fit right anyway
                        • Agree Agree x 1
                        • toolmanmike
                          toolmanmike Moderator Staff Member FABO Gold Member
                          68,563
                          61925
                          Jan 18, 2006
                          Iowa
                          Local Time:
                          8:56 AM
                          Fix the cause of the problem. I had those on my 65 years ago and a coil grabbed the lip of my gas tank and ripped it out from under my Dart when going over some rough railroad tracks at highway speeds. Good thing it slid down the highway and into the ditch and I kept driving up the hill. It could have been a bad deal.
                          • Agree Agree x 1
                          • kursplat
                            kursplat Well-Known Member
                            4,311
                            3289
                            Aug 24, 2010
                            so cal
                            Local Time:
                            6:56 AM
                            :wtf:
                          • toolmanmike
                            68,563
                            61925
                            Jan 18, 2006
                            Iowa
                            Local Time:
                            8:56 AM
                            Kersplat, That's exactly what happened. Noo fire. I was a lucky dog. Walked to a farm house and called dad. He came with the pick up and a chain and a couple 5 gallon gas cans.
                          • Professor Fate
                            3,743
                            5553
                            Jan 13, 2020
                            Wisconsin
                            Local Time:
                            8:56 AM
                            "Daaad- you ain't gonna believe this..." If I had a nickel... :lol:
                            • Agree Agree x 2
                            • toolmanmike
                              68,563
                              61925
                              Jan 18, 2006
                              Iowa
                              Local Time:
                              8:56 AM
                              I had just filled up too.
                            • Professor Fate
                              3,743
                              5553
                              Jan 13, 2020
                              Wisconsin
                              Local Time:
                              8:56 AM
                              "A tank of ethyl and a pack of Luckies, please. Here's a five, keep the change"...
                              • Agree Agree x 1
                              • toolmanmike
                                68,563
                                61925
                                Jan 18, 2006
                                Iowa
                                Local Time:
                                8:56 AM
                                That was back in 72 I believe. I didn't smoke yet. LOL
                                • Like Like x 2
                                • 65Val
                                  65Val Average Length Member
                                  5,265
                                  1277
                                  Oct 14, 2005
                                  Victoria, BC, Canada, EH!
                                  Local Time:
                                  6:56 AM
                                  How much are those? I bet you could get a pair of air shocks for less. This whole "top shock mounts blowing out" is a non-starter with me. I've had air shocks on several vehicles since the 70's, and never blew out the top shock mounts. I don't put 150 psi into them either....maybe 30. If you only need an inch or 2 of lift, get a set of air shocks, then get good springs when you can afford them.
                                  PS...check out my sig pic...air shocks with 30lbs in them.....just levels it up...rides fine!
