Header Gaskets...
68383GTS
East Peoria,IL
What are you guys and Gals sing for header gaskets?I need a set of high quality gaskets.I do not want to replace them in 6 months.I do not see much of a selection for 318-360 gaskets from Summit.I always used a high quality gasket from FelPro on my big blocks.I have the gakets with my Doug's header but I do not know how good they are.
Thanks,Jim
TTI makes a good gasket also, very thick and has the bigger port size for 340/360. I've had very good luck with these.
copper gaskets or ultracopper rtv is what I have always used I also coat header bolts with ultracopper run it through a heat cycle and re-torque and they wont back out
Percy's Seal 4 good. They are supposedly re-usable. I have no problems with them whatsoever. They sealed way better than the gasket that came with my Hooker header.
