Numbers 5 & 7 are hard. I have used the reusable valve cover gaskets from MP or Mr. Gasket. Otherwise, a socket and wrench do the job. As a second tip, the spark plug wires should use a wire loom to hold them away from the tubes. These 1 size fits all header normally can burn the #5 & 7 wires. Short 90* plug end boots help a lot here. Sometimes there not needed, sometimes there a must.I'm a little concerned about the plugs with these headers they look like they are gonna be super hard to get to.
Not all of these headers, manufacturer or batch run by them have the same clearance issues. I like to cut my own wire lengths and use aftermarket wire looks to hold the wires where I want them.
