Headlight switch
4spd mod
Member
Arkansas
Does anyone know where I can find a headlight switch harness or just the switch connector for a 69 Barracuda?
Post a want in the for sale want. If you can find an old one off an old harness that has the connector shell good, you can rebuild it with new terminals. If you cannot find one "right away" you can use individual flag/ spade connectors and carefully connect them to the switch individually
The harness connector for the headlight switch is the same in many Jeeps. Just search it for Jeep CJ. Jeep owners would melt them down by adding lights incorrectly. If the connector in your car melted, you need to hunt for why this happened. If you added frog lights without a relay and separate/dedicated power source, there is your cause.
Yes - same as in the Jeeps. This are the ones I use
Jim
