roccodart440
- Joined
- Apr 19, 2010
- Messages
- 6,896
- Reaction score
- 3,728
The only time you run the iron head is if you must according to the rules or you think you just gotta have that iron head.
Listen to what THE HEAD MAN is saying /\ /\ /\
I thought you had to cut out a section of the frame rail and weld in those spring relocation boxes?
That is an inboard kit. The offset shackles bolt in and you just need to weld a new perch.
I had the offset shackles and went to a inboard kit. Not really because I needed it but because it fell in line with other changes I was making so it made sense.
