heads up
mac daddy mopar
ohio
As I posted in another thread my air compressor pump went by the way of the dodo bird:angry7: but I ordered a new pump, no more oil free **** for me:bootysha:
don't know what was going on in my head when I bought the damm thing
but I'll never go down that road ever again:bootysha:(side note my brother swears
to be damm that I was peting it at sears when I called the wife and told her that I was going to buy it, but I still think he's full of ****)
any way my new pump gets here so I'm good to go or am I?
problem 1 pump don't want to go over 1200 rpm, ok no big deal . yea right the voice in my head say's.
problem 2 my motor is a 6.5 hp that spins 3450 rpm, what to do what to do?:dontknow: I know I'll ask the smartass at work what pulley I need to slow my motor down to 1200 rpm. you know the smartass in question, the one at every job the sob that knows it all. well guess what said smartass didn't have a clue. so back to square one I said to myself. so I did what any one with more than 7 brain cells would do. I hit the net, the information supper hyway
and by pure luck I stumbled on this site the gizmologist's lair and he has all kinda things going on check it out, I googled it myself. well what I googled was pulley ratio chart and ended up there. anyway he has a calculator on there ,you put in your hp number motor rpm pulley 1 dia. pulley 2 dia. and it
will tell you the rpm of pulley two. now I ask you how cool is that?
sorry for the long post went to a cookout tody and had a few ice cold ones:bootysha:
http://www.gizmology.net/
http://www.gizmology.net/pulleysbelts.htm
Resources for Tinkerers
The Gizmologist's Notebooks:
Notes on Spur Gears
Notes on Calculating Roots
Notes on Non-Refillable Gas Cylinders
Notes on Change Gear Setup
Notes on Tapers
Notes on "Guestimation"
Notes on Laying Out a Parabola
Notes on Laying Out an Arc Without a Compass
Notes on LEDs
Notes on Stereography
Notes on Bearing Nomenclature
Notes on Continuously Variable Transmissions
Notes on Pulleys and Belts
Notes on Chains and Sprockets
Notes on Motors
Notes on Batteries
Notes on Nuts and Bolts
Notes on Metals
Notes on Fusible (low-melting-point) Metals - New!
Notes on Tracked Vehicle Transmissions
Notes on Conic Frusta (tapered tubes)
Notes on the Development of Curved Surfaces
Notes on Pipe
Notes on Liquefying Air - New!
Notes on Repeating Decimals - New!
Notes on Rope Power Transmission - New!
Off-Site References:
Fundamentals of Engineering Reference Handbook by the National Council of Examiners for Engineering and Surveying (NCEES). 17.5 meg PDF download, but well worth it.
Lessons in Electric Circuits by Tony R. Kuphaldt et al.
A Guide to Filing a Utility Patent
How to drill a Square Hole
An Introduction to Ball Bearings by NTN products
Mister Spoc What is the population of Rijel 4 ?
I'm googling that now captain. LOL
The problem with the info super highway is what happens if the plug gets pulled. Will there be one person who can use a pencil and paper to calculate a ratio ?
Since the belt length will change on your compumper too, why not google the math involved rather than the answer. Cheers
