Heat/AC box resto kit.
Clelan
Inferno Red Duster
Martensville Sask. Can.
I just finished the resto on the Heat/AC box for my 74 Duster. I used your rebuild kit to do it. I just have to say it is a great kit with great instructions. I was going to do a Heat/AC box rebuild thread to assist others, but with the instructions in your kit it is not necessary.
Thanks for the great product.
Cley
*Note, I am not involved in DMT in any way other than being a very happy first time customer That will be ordering more items very soon.
Just finished mine - a 73 Dart Sport with AC. Kit is very nice, especially the photo instructions that come with it. Buy with confidence.
I am also doing this and also very pleased and amazed how easy it is. Just take your time and wow the only problem on mine was me on the vacume lines I might need someone to draw a diagram for me.
I'll also just mention that I used the DMT kit to rebuild my 73 Duster heat box and the products were totally perfect - fit, quality, everything.
Haven't had time to do mine yet, but did purchase the product and after looking at the instructions, I feel certain this will be a simple project
can you paint the doors with clear lacquer before you glue the foam on. will it stick? my doors were very rusty i don't want them to get rusty again
do they sell a housing repair kit? the doors rivets pulled through. i'm just going to nut an bolt it on but i want to patch around it .
their use to be a housing repair/paint kit that yearone sold but they dont anymore
I've never had great luck with clear lacquer on metal like that. I sandblasted my doors and sprayed them with satin black rust paint, then glued the foam on with Super 77. Worked perfectly.
I repaired some damaged rivet holes with Plastic Epoxy then redrilled the holes. With washers on the back (inside), new rivets went in perfectly.
I scrubbed the airbox clean, sanded it a bit and gave it a couple of coats of clear. Very happy with the results.
I just used 2 part epoxy for my housing repairs. But I had a spare box to cut patches out of. I imagine the foam will stick to the lacquer with the right glue.
Cley
Im working on (2) 80s trucks adding factory air to them, that came from the factory without.
I was able to make 2 good heater plenum boxes out of 3. The 3rd one had huge holes in the casing, either from rough handling in removal or else from storage. Between the 3 heater boxes I was able to get 2 each, good evaporators and heater cores. On one of the 2 good units there was a hole in the lower box casing, not that would have really kept things from being functional or anything.
But I cut the edges of the hole out to even things up and then cut a matching patch out of the "parts" heater plenum box. I then JB welded the patch in from the inside, and just the seams on the outside and ground/sanded that down so it's barely noticable.
I bought the "mega" heater box rebuild kits for both from DMT, but they didn't come with the foam for (I think it was) the blend air door.... There's 3 doors within these heater boxes. The foam on the same door was shot on all 3.
I went thru all the choices of foam from McMaster Carr and "guessed" the best I could as to which foam sheet to use. I bought (2), 12x12 squares of foam, I don't remember what I ended up using but found out later there would have been maybe a better choice but what I used worked fine as was. One characteristic I looked at was resisting mold, resisting actually like a sponge and soaking up all the moisture present on every AC system. I stripped all the old foam off the door and re glued the McMaster Carr foam into its place. The door out of one of the heater boxes I had here, wound up unusable. I basically had 1 of everything that was junk/ unusable out of the 3 heater/AC boxes I had to start with. I had "just exactly enough" good pieces out of 3 heater boxes to get 2 good usable ones.
Side note
When looking at DMT's site looking for the parts I'd need, they had a long paragraph about "not" having the foam that lined the doors within the heater box, and that it was a common question of customers, that they were looking for this particular foam. IDK if that appears on other sections of their site pertaining to parts for different vehicles than I'm working with... But thought it was important to put that out there for those other members that may have the same question/issue with theirs. IDK what the differences are in a heater box for what I'm working on vs those for an a body as it's been 30 years since I did a heater core on an A body and had an a body heater box apart... I've slept since then, and have a little bit of CRS on that subject haha
