Heater box
72RR Rick
Active Member
Aiken S.C.
What color paint should I use for box ? Want it to look close, not stick out. Thanks for any help Rick
Since its mostly plastic or fiberglass, I use SEMS landau black. The psint seems to stick good and look good on just about everything in these cars.
I used a method I saw in Mopar Magazine...
I sand blasted the housing (I have access to a cabinet at work), using VERY light pressure. I then sprayed a light coat of semi gloss clear coat over it. Looks Fantastic! If you don't have access to a blaster, you could always lightly scuff/sand the housing instead.
Hope this helps!
