HELP!!! Is this suspension safe?!
Huron33
Member
Michigan
Just purchased a mini tubbed 440 duster with 727 8 3/4 rearend. This is my first Mopar and there is just a extra bolt at the front of this cal- trac setup not bolting to anything and not tight. There is also an extra frame rail add it looks like....Can some one explain to me what the hell is going on?
You have prolly seen this car online for sale and man who ever did the fabrication on this thing was a hack. I'm in the middle on welding patch panels and restoring this thing and I noticed this. Here's a pick of the car be fire I started
Those are Cal Tracs. They are a traction device for leaf spring cars. They work pretty dang good.
The "extra frame rail" was added as part of the mini-tub. Your pictures don't show everything, but from what I can see it looks like it was done decently well. If you look at the 3" spring relocation kits out there you'll see there's nothing really crazy going on with the installation on your car.
Looks like **** work to me!
Based on what? You can't really see the quality of the welds in his pictures. Spray some random undercoat and let things surface rust a bit and everything looks like crap. Yeah, the tubing added to the frame wasn't cut back to be flush with the frame, but so what? Doesn't hurt anything as long as it doesn't interfere with the caltracs.
Okay, I see what he did now. The reason the new spring pocket doesn't like up with the existing frame rail is because he lengthened the wheelbase by one inch for tire clearance.
Just odd how the metal in the frame rail was cut around the bolt location. I've built a few rides before so it looks suspicious.
Cut flanged and fitted ready to stitch it up.
Well **** man, if you don't like it, take it off and send it to me. I'll take it.
The frame box was cut around the bolt for clearance because of the way the box was installed. Instead of sliding the box all the way into the original frame rail up to the subframe it was left further back to move the axle back. That centers the rear axle in the wheel tubs so taller tires can be used. The result is that the spring box sticks out, and had to be trimmed for clearance. It's probably also a home made spring box, but all the spring box really is in the relocation kits is a piece of square tubing. Compared to the Mopar performance kit there's nothing you couldn't build easily at home. The US Cartool kit is better quality, but again, it wouldn't be hard to replicate. Just take some extra time and metal. The nicest thing about it is that it bolts to the original spring hanger mount so you don't have to worry as much about locating everything properly. But back to your car, there's no strength in the section that's trimmed, you could cut the entire box back so it's flush with the rail. Wouldn't hurt a thing as long as you didn't cut the welds holding it in place.
Your other choice would be to reinstall the spring box as it's supposed to be installed, sliding it forward into the rail up against the crossmember. But if you do that you'll have to shorten the driveshaft if you've got one that works with the current set up.
It may be a home built Caltrac set up, but I don't see any reason it wouldn't work the same. But I'm just going off the pictures. Maybe it's not as pretty, but it looks plenty functional.
looks like it is designed to articulate. when accelerating the free bolt will push down against the spring locking the traction bar and limiting twist, any other time it will be free to move. the reason for this is to stop rear steer as the wheels ride bumps and dips in the road with the traction bar pulling at the axle. rear steer can be exaggerated with traction bars at different ride heights as to whether the fuel tank is full or empty, trunk full of stuff etc.
you could put a rubber sleeve on that bolt to stop it clacking against the spring when you hit the throttle.
Thanks for the thorough respond 73BluNblu and Bozwel So in your opinion it is safe? Or do what 72bluNblu suggested.
looks fine to me. i'd run with it.
the only issue I can see is the pivot bolt (leaf spring bolt) cannot be done up tight otherwise it'll stop the unit articulating.
as that bolt can only be lightly tightened it'll need a Nyloc nut or two nuts locked together to hold in place. unfortunately it'll allow the leaf spring bush to rotate slightly. If that is a rubber bush in there change it for nylon top hat bushes that are a perfect fit. it'll have less flex but allow radial movement, plus it will act as an antiroll bar limiting the amount the leaf springs can twist on cornering.
I may copy that design for the rear of my Barracuda.
I think it's safe, but that's just my opinion based on a few pictures on the internet. I don't know if it's set up properly for your car or if it's working as it should be. But based on what I can see I don't think it's unsafe, the springs aren't going to fall off the car or anything.
that's an idea that might be worth thinkin about. but their supposed to be preloaded a certain amount when right.
