Dodgeboy68
Active Member
This is about the 68 dart in the avatar. This was a slant six car i bought in 2007 and did a partial restoration on it. Put a 440 in it and converted all the drive line to heavy duty v8 stuff. Converted the light duty slant six brakes to a set of disc brakes that came out of a 73 dart. The car has just 73 dart manual disk brakes with no upgrades.
What I am dissatisfied with is that it takes a lot of pedal pressure if you want to stop the car quickly. It has a hard high brake pedal but I cannot apply enough pedal pressure to make the tires even slip a little bit. It has the dual master cylinder that was stock on a 68 disk brake car. The installation of power brake booster is pretty much not possible because the car is equipped with the hooker fenderwell headers.
Any suggestions to improve the brake performance good enough for a daily street driver would be appreciated.
