Help needed identifying k member
discharger1332
silverdale wa.
I got this k member with a load of parts years ago. Was told that it was modified for a big block? I’m pretty sure that’s not true but not sure as I’ve never actually seen one. The long measuring is from top of perch to top of perch. The short is hole to hole. It definitely has 67 style idler arm.
It has been modified for big block oil pump clearance on the left motor mount pad, but that's all I know. @Jim Lusk might can tell you more.
Yes it is a modified small block k-frame to let the big block oil pump not hit. I have one that looks almost identical in my 69 GTS that was a 340 car and had a 383 in it when I bought it.
It uses specific brackets.
It is a modified for big block k member though. Usually that's narrowed and boxed in, but that works.
Fyi Small block and slant 6 k members have the same drivers side tower 67-72
Cut the pass side off and make a new one
Or if it is a S6 u can use the thicker truck biscuit on the pass side. Or so I was told, it may be fiction but not fact as I have never tried it. Kim
