hpgs
I recently inherited a 70 dodge dart swinger with a 340 4 speed. It has been converted to electronic ignition and some other aftermarket stuff done such as a 30 amp fuse added in on the fire wall. The problem started at a car show, it drove great to the show but when I went to leave I turned the key and nothing. The fuse that was added on the fire wall was blown so changed it and the car fired right up. Drove a few hundred feet and it blew again. Put a new fuse in then a crank no start problem. With some testing found out the electronic ignition module was faulty so I replaced that. Now the car will run but the gauges other then the volt gauge don't work and the left signal lights stopped working along with the interior dome light. I checked the fuses under the dash and they have power on both sides of all fuses.I am new to these cars and looking for any advise on where I should start looking for the problem. Sorry for the long winded post.
