Well..there is a little piece of pipe coming from the catalytic converter and connecting to the smog pump with some sort of check valve and rubber line, that valve burnt out and melted the rubber line and part of the smog pump...so I chopped the rubber end off and put a kink in the pipe sticking out of the side of the catalytic converter so I didn't have an exhaust leak
Well you gotta ask yourself why that happened........
To test for a restricted exhaust, What I do is braze a foot of brakeline into the exhaust pipe at about a 45* angle, with about an inch into the pipe, and between the cat and the engine.. On the other end I plumb a vacuum line up into the cab and install a low-pressure gauge there. I use a combination Vacuum/ fuel-pump tester. Then I go for a road trip,testing various modes of operation.
4psi is very restrictive. You want to see under 2psi. Between 2 and 3 it's a judgement call.
But at this time you don't really know if the pressure is caused by the cat, or by the muffler, or even by the pipe! So you gotta braze another piece of brakeline in,this time between the cat and the muffler.....and then another road test.
If you are Ok here, then the cat has to go.
But if the pressure is also high here, then replace the muffler first, then retest the cat. Unless;
Unless if you see questionable pipe splices behind the muffler; check those before replacing the muffler.
It sounds like a lotta work, but really it's not,and........ you get to replace only the bad part .......the first time.
