octanejunkie
Mopar Padawan
I would need all of your info to spec a cam.
It's all in this thread but I can PM you all the dets later today
x2 and with that 276 gear it'll be a poochMan that's sure a lot of compression for a cam that small. You'll probably be lucky if you get it to run decent on high octane pump gas without dropping the timing way back.
If you could open up the chambers to 64cc with a chamber cut, you could use a cam with 230@ .050 on a 112lca and about .550 lift with 1.6 rockers.
Thanks Brian
The chambers of my heads measured out right around 62.5-63cc (http://www.forabodiesonly.com/mopar/showpost.php?p=810483&postcount=8)
Would polishing the chambers open them up to 64 or do I need to remove more material? If I need to remove material, from where do you suggest?
Just heard back from the grinder, they can do the following roller for the magnum 360
287 (228 @.050) 525 @ 1.6 intake
298 (234 @.050) 512 @ 1.6 exhaust
110 LSA
The Hughes 1103 spring (120# @ 1.660' INSTALLED 310# @ .550' LIFT) would be fine in their opinion
How are them apples?
For what you are doing and the head gaskets to choose from, I like it.
Hi friends, I'm newer here.
Do you know if the LA cam and lifters fits in Magnum engines? I kow there are differences like magnum have oil trough the pushrods, the rockers, roller cam and lifters, intake and another differences. I don't find this informtion yet... thanks!
