Help with frame height
gdizzle
los angeles
Anyone know approximately what the distance from the road to the K member frame should be? Mine seems really low to the ground, and is scraping in some dips. I have 66 dart sedan with the slant. thanks
Show us a picture. You can jack up the front end (use jack stands) and adjust the torsion bars with a 3/4" socket. I measure to the top of the wheel opening to get them even or 3/16- 1/4" higher on the drivers side to compensate for driver weight.
With the slant and slant torsion bars you probably want at least 1.5" between the lower control arm bumper and frame. Fenders could be off a bit so it is best to measure frame height to even the sides.
