ramenth
Gratis persona
I need more...lol.....450 is boring anymore.
When it comes to horsepower enough is enough, but too much is just right.
speed cost money
there are 10 ways you could go but they all will cost you, barbarian
1. gen iii with kenne bell twin screw supercharger,allowing you to keep stock compression ratio lol. has liquid cooling optionand air-to-water intercooler.
http://www.hotrod.com/how-to/additional-how-to/1407-kenne-bell-twin-screw-supercharger-kits/
2. if you have $75k+ get a goodwin 650 c.i. hemi. good night.
3. you can do cheaper gen 3 supercharger builds, which add about 7 to 8 lbs boost. should get you 550 hp or so.
all the gen 3 options will require hemidenny kit etc.
there are a ton of different supercharger options and stuff for the gen3's now. all kinds of stroker kits yadi yadi yadi. lots of money to be spent!
4. gen 2 hemi you are looking at 700 - 900 hp on pump gas but also a $15k - $20k bill
5. stroked 440 or 400 you are looking at probably a $10k cost.
6. turbo small block 360 you will have a lower cost but be ready to fab & weld. etc.
watch out overdoing the boost.
7. supercharge small block but again watch out for too much boost.
8. keep what you got get the heads ported, & some springs for a little more lift. swap to efi you can get more power out of your current build.
9. keep what you got and run it. build another on the stand.
10. do nothin just run it save your money for trips and stuff & send cool gifts to all your homies on fabo
Supercharged small block. Big blocks and hemis are a packaging nightmare in an A body.
Decided to go a different direction with the 67 cuda.
Going to go big street horsepower but not sure if I should go with a hemi or a 440 based big block stroker with option 3 keeping my current 360, lowering the compression and adding a pro charger set up.
Keeping in mind it will take roughly 5'years to build as I collect parts.
Any advice or opinions real or fake?
Just for fun......what say you?
Currently pushing roughly 450 horse 11.0-1 366 cubed small block.
I'd like to get to the 550-600 hp range.[/QUOT
I like supercharged ,small block. Myself personally, would do the centrifugal. If you want the bad *** thumper look, Rootes blower,the whole way.
