Hemi Swap Info
Does ANYONE have a drawing of the ECM, showing the pin #/ wire color and what they feed?This was easy to find for doing a Magnum swap but seems to be a big secret for the Hemi swap.
Tom
Tom
Yes, I've been looking high and low for a full size electrical drawing. I'm going to start making my own!
Here is what I used, its for an 05 Ram 1500. The connector cavitiies should be numbered if I remember correctly. Hope this helps!
MODULE-POWERTRAIN CONTROL C1 (NGC) - BLACK/BLACK 38 WAY
CAV CIRCUIT FUNCTION
1 K98 18DB/YL (EXCEPT 3.7L) COIL CONTROL NO. 8
2 - -
3 K97 18DB/YL (4.7L) COIL CONTROL NO. 7
3 K97 18BR (5.7L) COIL CONTROL NO. 7
4 K28 18BR/LB (EXCEPT 3.7L) INJECTOR CONTROL NO. 8
5 K26 18BR/YL (EXCEPT 3.7L) INJECTOR CONTROL NO. 7
6 - -
7 - -
8 B222 20DG/WT (5.7L) VEHICLE SPEED SIGNAL NO. 2
9 Z130 16BK/BR GROUND
10 - -
11 F202 20PK/GY FUSED IGNITION SWITCH OUTPUT (RUN-START)
12 F1 16PK/WT FUSED IGNITION SWITCH OUTPUT (OFF-RUN-START)
13 B22 20DG/YL VEHICLE SPEED SIGNAL NO. 1
14 - -
15 - -
16 - -
17 - -
18 Z131 16BK/DG GROUND
19 - -
20 G6 18VT/GY OIL PRESSURE SIGNAL
21 C918 18BK/LB A/C PRESSURE SIGNAL
22 G31 18VT/LG AAT SIGNAL
23 - -
24 - -
25 D20 18WT/LG (3.7L/4.7L) SCI RECEIVE (PCM)
25 D20 20WT/LG (5.7L) SCI RECEIVE (PCM)
26 D16 18WT/OR (EXCEPT 3.7L/4.7L A/T) SCI RECEIVE (TCM)
27 F856 18YL/PK 5 VOLT SUPPLY
28 - -
29 A919 20RD FUSED B(+)
30 T751 16YL IGNITION SWITCH OUTPUT (START)
31 K141 18DB/YL O2 1/2 SIGNAL
32 K902 18BR/DG O2 RETURN (UP)
33 K243 18BR O2 2/2 SIGNAL
34 - -
35 - -
36 D21 18WT/BR (3.7L/4.7L) SCI TRANSMIT (PCM)
36 D21 20WT/BR (5.7L) SCI TRANSMIT (PCM)
37 D15 18WT/DG (EXCEPT 3.7L/4.7L M/T) SCI TRANSMIT (TCM)
38 D25 20WT/VT PCI BUS
MODULE-POWERTRAIN CONTROL C2 (NGC) - BLACK/ORANGE 38 WAY
1 K10 18DB/OR COIL CONTROL NO. 6
2 K16 18DB/YL COIL CONTROL NO. 5
3 K15 18DB/GY COIL CONTROL NO. 4
4 K58 18BR/VT INJECTOR CONTROL NO. 6
5 K38 18BR/OR INJECTOR CONTROL NO. 5
6 K447 18TN/YL (5.7L) ETC MOTOR (+)
7 K18 18DB/OR COIL CONTROL NO. 3
8 K35 18DB/VT (4.7L/5.7L LD) EGR SOL CONTROL
9 K17 18DB/TN COIL CONTROL NO. 2
10 K19 18DB/DG COIL CONTROL NO. 1
11 K14 18BR/TN INJECTOR CONTROL NO. 4
12 K13 18BR/LB INJECTOR CONTROL NO. 3
13 K12 18BR/DB INJECTOR CONTROL NO. 2
14 K11 18BR/YL INJECTOR CONTROL NO. 1
15 K922 18BR/DB (5.7L) TP SENSOR RETURN
16 - -
17 K199 18BR/VT O2 2/1 HEATER CONTROL
18 K99 18BR/LG O2 1/1 HEATER CONTROL
19 K20 18BR/GY GEN FIELD CONTROL
20 K2 18VT/OR ECT SIGNAL
21 K22 18BR/OR TP NO. 1 SIGNAL
22 K34 18DB/LG (4.7L/5.7L LD) EGR SIGNAL
23 K1 18VT/BR MAP SIGNAL
24 K942 18BR/LG (EXCEPT 4.7L) KNOCK SENSOR NO. 1 RETURN
25 K42 18DB/YL (EXCEPT 4.7L) KNOCK SENSOR NO. 1 SIGNAL
26 - -
27 K900 18DB/DG SENSOR GROUND
28 K122 18BR/DG (5.7L) TP NO. 2 SIGNAL
28 K961 18BR/VT (EXCEPT 5.7L) IAC SIGNAL
29 F855 18PK/YL 5 VOLT SUPPLY
30 K21 18DB/LG IAT SIGNAL
31 K41 18DB/LB O2 1/1 SIGNAL
32 K904 18DB/DG O2 RETURN (DOWN)
33 K43 18DB/LG O2 2/1 SIGNAL
34 K44 20DB/GY CMP SIGNAL
35 K24 20BR/LB CKP SIGNAL
36 K242 18BR/WT KNOCK SENSOR NO. 2 SIGNAL
37 K924 18WT/BR KNOCK SENSOR NO. 2 RETURN
38 K448 18TN/OR (5.7L) ETC MOTOR (-)
38 K61 18VT/GY (EXCEPT 5.7L) IAC CONTROL
MODULE-POWERTRAIN CONTROL C3 (NGC) - BLACK/NATURAL 38 WAY
1 - -
2 - -
3 K51 20BR/WT ASD RELAY CONTROL
4 - -
5 V35 20VT/OR (3.7L/4.7L) S/C VENT SOL CONTROL
6 K173 18BR/VT CONDENSER FAN RELAY CONTROL
7 V32 20VT/YL (3.7L/4.7L) SPEED CONTROL SUPPLY
8 K106 18VT/LB NVLD SOL CONTROL
9 K299 18BR/WT O2 1/2 HEATER CONTROL
10 K399 18BR/GY O2 2/2 HEATER CONTROL
11 C13 20LB/OR A/C CLUTCH RELAY CONTROL
12 V36 20VT/YL (3.7L/4.7L) S/C VACUUM SOL CONTROL
13 - -
14 V32 20VT/YL (5.7L) BRAKE SWITCH NO. 2 SIGNAL
15 V937 20VT/BR (5.7L) S/C SWITCH RETURN
16 K167 20BR/YL (5.7L) APPS NO. 1 RETURN
17 K400 20BR/VT (5.7L) APPS NO. 2 RETURN
18 V38 20VT/OR (5.7L) S/C SWITCH NO. 2 SIGNAL
19 K342 16BR/WT ASD RELAY OUTPUT
20 K52 18DB/WT EVAP PURGE SOL CONTROL
21 T41 20YL/DB TRS T41 SENSE
22 G113 18VT (EXCEPT 3.7L/4.7L BASE) PTO SWITCH SENSE
23 B29 20DG/WT BRAKE SWITCH NO. 1 SIGNAL
24 - -
25 K23 20BR/WT (5.7L) APPS NO. 1 SIGNAL
26 - -
27 - -
28 K342 16BR/WT ASD RELAY OUTPUT
29 K70 18DB/BR EVAP PURGE SOL SIGNAL
30 K66 18DB/WT (5.7L) P/S SWITCH SIGNAL
31 - -
32 K25 18DB/VT BATT TEMP SIGNAL
33 N4 20DB/WT FUEL LEVEL SENSOR SIGNAL
34 V37 20VT S/C SWITCH NO. 1 SIGNAL
35 K107 18VT/WT NVLD SWITCH SIGNAL
36 K29 20WT/BR (5.7L) APPS NO. 2 SIGNAL
37 K31 20BR FUEL PUMP RELAY CONTROL
38 T752 20DG/OR STARTER RELAY CONTROL
MODULE-POWERTRAIN CONTROL C4 (NGC) - BLACK/GREEN 38 WAY
1 T60 18YL/GY OD SOLENOID CONTROL
2 T259 18YL/DG 4C SOLENOID CONTROL
3 - -
4 T140 18DG MS SOLENOID CONTROL
5 - -
6 T219 18YL/LG 2C SOLENOID CONTROL
7 - -
8 T59 18YL/LB UD SOLENOID CONTROL
9 - -
10 T20 18DG/WT L/R SOLENOID CONTROL
11 T118 YL/VT (3.7L/4.7L) PRESSURE CONTROL SOLENOID CONTROL
11 T118 18YL/GY (5.7L) PRESSURE CONTROL SOLENOID CONTROL
12 Z908 18BK GROUND
13 Z977 18BK GROUND
14 Z904 18BK GROUND
15 T1 18DG/LB TRS T1 SENSE
16 T3 18DG/DB TRS T3 SENSE
17 T6 18DG TOW/HAUL OVERDRIVE OFF SWITCH SENSE
18 T515 20YL/DB TRANSMISSION CONTROL RELAY CONTROL
19 T16 18YL/OR TRANSMISSION CONTROL RELAY OUTPUT
20 T48 18BR/YL 4C PRESSURE SWITCH SENSE
21 T29 18YL/WT UD PRESSURE SWITCH SENSE
22 T9 18DG/TN OD PRESSURE SWITCH SENSE
23 - -
24 - -
25 - -
26 T4 18DG/VT (3.7L/4.7L) TRS T2 SENSE
26 T4 18DG/LB (5.7L) TRS T2 SENSE
27 - -
28 T16 18YL/OR TRANSMISSION CONTROL RELAY OUTPUT
29 T50 18YL/TN L/R PRESSURE SWITCH SENSE
30 T147 18DG/LG (3.7L/4.7L) 2C PRESSURE SWITCH SENSE
30 T147 18DG/YL (5.7L) 2C PRESSURE SWITCH SENSE
31 T38 18YL/BR LINE PRESSURE SENSOR SIGNAL
32 T14 18DG/BR OUTPUT SPEED SENSOR SIGNAL
33 T52 18DG/OR INPUT SPEED SENSOR SIGNAL
34 T13 18DG/VT SPEED SENSOR GROUND
35 T54 18DG/OR TRANSMISSION TEMPERATURE SENSOR SIGNAL
36 - -
37 T42 18DG/YL TRS T42 SENSE
38 T16 18YL/OR TRANSMISSION CONTROL RELAY OUTPUT
Thanks ralphie361, that's what I was looking for. I'm working on an 04 unit, but i'll bet it's the same.
Thanks again,
Tom
Update: 4/10/2015
I am building a wiring cross reference sheet and my first stand alone harness. Believe it or not dodge used several different pin out configurations on the ecm's through the models an years. 03 ram, 04-05 ram, 06 ram all slightly different pin outs on the NGC connectors.
It is hard to make a one size fits all tutorial without the connector pin cross reference.
Update: 4/10/2015
Keeps us posted on the progress!
This is great that you are putting the effort into getting the information out. The lack of info readily available is a large part of the reason the Chrysler swaps are less popular than the Chevy/Ford. Make the info available and they will come. Letting folks know they can accomplish a swap without having to send thousands of bucks worth of Chrysler tax to someone who holds the golden ticket.
I have stumbled backwards into a 5.7 swap into am A100 pickup when my old 318 turned into a money pit to get it where it needed to be. I will be using a NAG1 as it is short enough to work in this little thing. Not many options when you have a 90" wheelbase and the engine is behind the front axle centerline. I don't have any solutions yet for the engine and trans electronics but am aware of the intrinsic difficulties with the NAG. I know of the two "popular" stand alone options and the one where you send the pile of controllers out and have it reflashed. I would prefer to use easily programmable controllers and I suppose cracked OEM ones would fulfill that requirement. I'm also fine with using Mega Squirt for the engine and one of the stand alones for the trans.
Bla bla bla, anyway, thanks for your efforts and I am following this. I have ordered my 2013 truck 5.7 and it should be heading this way soon, the NAG is on the floor so it will be coming together soon enough.
Im definitely going to be following this thread. Im picking up an 05 Rumblebee transmission/harness/fusebox/converter/ecu/driveshaft tomorrow for $350 total. So id like to take advantage of this deal i have on all these parts and try to use it to save me a bunch of money on this swap in the long run. I've been working with electronics and advanced radar and weapon systems the last 10 years in teh Navy so im looking to try my hand at a harness of my own first before I pony up $1000 for a hotwire harness. Thanks for all the work your doing Yellowfin, ive been messaging people on here who have done the swap themselves and all i can get is "here are the books I used as a reference, figure the rest out yourself". I appreciate the small nudge in the right direction but come on guys share teh info it will make for a better more educated community faster.
If they gave you the info that they used to successfully modify their harness, short of doing it for you, it seems to me they have done everything they can to help you.
As nice as it would be to have a simple pinout for a harness, its much too complicated for that. Pinouts change between ECU's and models as mentioned, optional systems muddy it up even more.
Paring down a factory harness in a retrofit is going to be extremely time consuming.
It all depends on how long it takes you to save up the $1000 for the hotwire harness.
That pin-out list for the 05 Ram is a great start. Just need the same for the 08 300 SRT8 and I am away I think. Having a cross-reference would be a great help for everybody.
Ive got the manuals and picked up my trans/harness/ecu from an 05 Rumblebee today and im in no rush so ive got plenty of time to try and get this done myself. Hopefully with just the nudges ive gotten so far. If i can get it all knocked out myself ill share amy wuccesses or failures I have.
I am really glad you guys are tackling this. I am looking for a hemi now to do the swap into my 68 notch. It will most likely end up with the 5.7 and a 6 speed. This info will help me and guys like me a bunch. Thanks again.
I take it you guys havent figured out that you can get a cd from ebay with a 6-10 year spread on a Ram or Durango or .... FSM that has all the different years of wiring of diagrams of the pcm as well as all the connectors for $15?
Update: 4/10/2015
Believe it or not? lolol Oh, I believe it! I believe it!
Any links?
Advancements have been made and we are moving right along. I have a cross reference excel spreadsheet comparing pin for pin, the 2004-2005 Ram ECM VS the 2006 LX car ECM. Available to anyone who wants it, just email me.
I also have modified my GM bench tuning interface to work with NGC Chrysler ECM's.
It isn't the prettiest at the moment because I am doing some R&D on the design, but it is functional.
Hopefully I will have the tuning out of SKIM functions resolved by working with HP tuners soon. Once that is done, I can test my harness for functionality to verify that my methods are correct. If it all works, I will publish the info for the Mopar Community. It's time we start sharing info with our brethren!
Email me at tacticalspeedsolutions@gmail.com for Hemi Swap Related info, as I check it a heck of a lot more often right now. I'm so focused on figuring this out that I rarely frequent the forums here recently.
I also have the following available for sharing:
Hemi PCM Pinout Spreadsheet
2004-2005 Ram Factory service manual with wiring diagrams
2006 LX Car Factory Service Manual with wiring diagrams
HP Tuners Base and modified calibration files for various Hemi vehicles
Wow, that's some excellent work! Glad to see someone stepping up and getting involved in de-mystifying these computers.
