furyus2
Couldn't have been said better. I like Holleys. Easy to work on, get parts for, tune etc. It's critical to have a good filter on a Holley.I'm a lifetime Holley user and prefer them. But I am starting on a slow path to learn about Thermoquads.
You have to know why the float stuck. Holleys are very sensitive to a spec of dirt getting stuck between the needle & seat. Just about all carbs I'm aware of have a similar set-up but I don't know if the sensitivity varies. Gotta run a good filter in all cases and be careful when working on the fuel lines anywhere in between so no debris, like rubber hose specs, get into the system.
I currently have a 750 Race Demon on my 64 Sport Fury. I love that carb. It works flawlessly, Just an occasional cleaning. Ran a much faster ET than an 850 Holley.
Right now, I am running an AVS on my 69 Dart 340. Had to put an electric pump on it just to get fuel to the carb after sitting. Once you get it some fuel, it runs outstanding. The car is much faster than I thought it would be with that carb.
