T67POWER
- Joined
- Sep 30, 2009
- Messages
- 669
- Reaction score
- 10
Do you feel that your holley carb is set up right and works perfect for you???
If you feel that it is, then please list what your combination of carb parts are.
JETS\PUMP SHOT SIZE-FRONT AND REAR\ACCELERATOR PUMP CAMS AND THERE POSITION (HOLE USED)PLUS MOST IMPORTANT THE COLOR USED\CC'S FOR THE ACCELERATOR PUMP\AND WHAT POWER VALVE.
THIS INFO WILL HELP ALL THE MOPARS GO FASTER AND FASTER.
:glasses9:CALLING ALL HOLLEY SCIENTIST( THANKS \\\\ T67POWER)
P.S.PLEASE LIST WHAT KIND OF SPACER YOU USE IF YOU USE ONE.
