Holley, different carb sizes / same parts?
360duster
Bavaria / Germany
Hi guys, i´m wondering about the cfm rating of Holley carbs. You can buy main bodies and throttle plates from a lot of manufacturers, they say these parts can be used from 650 - 800 cfm DP´s, for example. I do have a 650 DP (list no. 80777) and wonder what causes the differences in air flow capability to the bigger ones if it´s not the main body or the throttle plate?
Maybe some experienced guys can give me some info, Thanks!
Michael
Michael
Its in the mainbody & throttle plates, If you get a decent holley book you'll learn alot i'll tell ya, the base plates on the DPs are the same size from the 650-800 carbs, the difference is in the mainbodies/boosters sizeing.
Throttle bores differ, as well, and so do the booster venturi's
Thats what i meant when i said "mainbody", that should cover it all sir isaac newton. :-D
I don't think we need any sarcasm? I understand you to say up above that "the base plates on the DPs are the same size from the 650-800 carbs" but that is where the throttles are
Just try'nna be correct. It's been awhile since I've had a stack of 650-850 dp's in front of me, and that HAS happened, a long time ago.
Throttle plates in the baseplate are the same size from 650-800 carbs... 1 11/16"
850's are 1 3/4"
Of course the bores in the main bodies differ slightly in taper, etc. on those size carbs from 1 1/4 to 1 7/16 venturi size.
I'm just jackin with ya :-D
Thank you guys for the info, got it now. I thought the main bodies are the same from 650 - 800 cfm, but this is not the case. 650 cfm carb has got smaller venturi size and that´s why there´s a difference in airflow.
greetings from Germany
Michael
