SSG_Karg
Enhanced member
I’m having a helluva time trying to get rid of a stumble in my tune up. It happens at very light throttle while cruising when I try to roll into it just a little. It’s like a little hiccup then it smooths right out.
Setup:
318, comp xe268, action plus, headers. Carb is OLD Holley 4777 650DP.
71/82 jets
31/31 shooters
Blue pump cams in #2 position
Floats are at the bottom of the sight hole
Timing is 22/34 Vacuum pod is plumbed to spark port.
IAB at 1.5 out
10.5 PV
10” hg @ idle , around 20” at cruise.
Transfer slots are .045” exposed
Idles at 800
Where should I start? It runs good everywhere else and I don’t want to totally destroy the tune while chasing this damn stumble. I unhooked the vacuum pod and plugged it and the stumble was totally gone, but I would like to keep the vacuum advance.
Should I start by drilling out the IFRs?
Setup:
71/82 jets
31/31 shooters
IAB at 1.5 out
10.5 PV
Idles at 800
