KnuckleDuster
Ran the car at the track Friday.
No issues. Drove the car Sunday and all was good. No smoke, no overheating, nada.
It was 28° here last night , but warmed up today.
Went to crank it an hour ago and it didn't want to. Acted like the starter was stuck.
Finally cranks and after running for a few I notice white smoke out the passenger bank.
Thinking it was condensation checked the dipstick, and the oil looked fine.
I let it run on fast idle, but it didn't clear up.
Than I looked and saw the temp was about 215° and shut it down.
Felt the radiator and it was stone cold. Opened it and dry pressure escaped, no coolant to be seen.
I think the intake gasket failed. I reused after head porting them because they looked fine. Guess that was a bad idea.
Plugs 6 and 8 are a little wet.
So as far as I know it only ran a few minutes with coolant in it at idle.
My question is how much damage do you think it did? It ran a max of 1500 at idle for 6-8 minutes.
It was running fine other than the smoke. I don't hear any knocking or strange noises.
About to go drain the oil and start pulling the intake.
Could the bearings still be ok?
