How hot is safe for my engine
pest1688
Member
port st lucie
Hi how hot should my engine be running. my 318 runs at 180 to 190 with ac off and 190 to 200 a/c on when temp outside is 80. I notice it runs hotter 190 on the hywy and around town 175 to 180. Are these numbers acceptable? Thanks!!
I agree.....not a biggie. It's not even boiling temp yet, and that temperature is measured as it's leaving the engine, up @ the water elbow, right? I don't like anything over 200 and definitely 215 (mostly 'cuz it increases the likelihood of pinging) I go nuts when it just keeps creeping up......220, 225....230.
Dual electric fans on a be cool alum radiator will anyways keep that engine cool!
With good antifreeze and a good radiator cap (and no leaks) it won't start boiling until its over 230.
To me, it sounds like you're running in a pretty good range. I don't think I'd spend any money to change it.
