How I solved my droning problem..
serodgers66
Member
Pittsburgh
I recently replaced my two piece headers with a stock manifold on the driver's side and a 90's magnum manifold on the passengers side. The headers rattled and leaked constantly and were a little too loud for my tastes. The unintended consequence was that I picked up a very pronounced drone when stopped at a light with rpm's between 750 and 1000. Like unbearably uncomfortable. Not necessary loud but it was like sitting inside a bass drum. I took it to a transmission shop thinking it may be my torque converter but everything checked out ok. So I chalked it up to a harmonic frequency issue. The exhaust is a 2.25" X exhaust that feeds into two Dynomax Turbo Mufflers that exit right before the rear axle. Before I sunk unneccesary $$$ trying to resolve the drone, I decided to pick up two Thrush Welded mufflers at the local parts store. I installed them and no change...actually, a little worse. I was in the middle of changing back to the turbos when I thought, "I wonder what it sounds like with one of each? Will the difference in backpressure solve the drone?" So I only swapped one Thrush for a turbo and took it for a spin. To my surprise, the drone was reduced considerably!! Not completely gone, but enough of an improvement that I can enjoy driving the car again. Just thought I'd share in case someone is battling something similar....
I don't remember what they are called, but some modern systems, and I think some of the Mustangs used them, are dead end tuning stubs. These are specific lengths of pipe, resembling a cutout or something, that are sealed on the end. Science, and all that.
Here we go:
Helmholtz exhaust resonators
Helmholtz resonance - Wikipedia
Google Search
you changed the resonance on one side and it interfered with the resonance on the other and reduced the drone. you had 2 Church organ pipes... in full song at one rpm, now you don't
bore and pipe length play a part so id guess with 2 similar mufflers their drones combined into a super drone.... at a specific rpm
now when one comes on-song it disrupts the other....= way less drone
Surprisingly Pontiac did both things mentioned above on the '67-'69 GTO's with automatics. They used a 2" shorter muffler on the passenger side and in '68 they added a Helmholtz resonator in the tailpipe too. Ford used the same muffler approach on the earlier 5.0 Mustangs.
Found this video. This guy's explanation makes sense. They seem to operate exactly like a 1/4 wave rf stub, such as used in TV coax to eliminate a specific interfering signal
Bear in mind, Rusty, that there are production cars that have used this. I can't name them all because the only way to find out is accidental, someone talking about it, or being "under" them and noticing. At my age, LOL I don't do that much anymore. Besides, all this new stuff is way too close to the ground.
A very quick search says Viper and V10 Rams. That 96 that I junked did not.
BMW's use them in the INTAKE
Someone claims they saw one on a Renault LeCar (pronounced ugLE CAR) LOL
https://media.ford.com/content/ford...-ford-engineers-tackled-the-dreaded-wind.html
Helmholtz resonators would be tough on an A body. Not much real estate JMO
LOL you could always run them up into the body, like one racer I saw did with the air intake ducting. I've always wondered how that might go if the turbo blew up the intake duct!!!
I too had an annoyingly loud drone (around 35 mph) for years inside of my Duster with my old Flowmaster mufflers. I eventually swapped them out for some stainless Borla Pro XS mufflers. Not much improvement. Then I added some "resonators" at the exhaust tips. Still no improvement. Finally, I added some homemade closed tube/chambers as described above by others, onto the tail pipes. The drone disappeared completely. I used some 3" tubing and made them as long as I could fit above the leaf springs. That was 5 years ago. I am beginning to suspect that the typical big quiet passenger car mufflers that we always removed as kids use some of that extra space inside for similar noise cancellation physics.
"exit right before the rear axle" but how? Turned out? Turned down? Also, where are the mufflers in your system?
I think his mufflers are in stock location and tips are on inside along the frame rails . I pic from the back would be nice.
TONS of cars have Helmholz resonators in the intakes. Buell motorcycles had them on intakes and exhausts, too
There is a lot of droning in my car. I have traced the source to my wife. Anyone have a fix for that?
If you can't figure out what to stick in her mouth when she opens it...
One of the best sounding cars I ever heard was my friend Eric's Fifth Ave. He put a header on the driver's side, stock manifold on the passenger side, stock muffler on the header side, and turbo muffler on the manifold side. It sounded like Arnold Schwarzenegger in a tuxedo.
Hey! Maybe that explains why the Mustangs are always going sideways and crashing when they break the tires loose. :steering:
