how many people have 10 cars or more in one ???
69 dart
96 jeep gas tank
95 ram 5.9
95 b3500 serpentine setup
92 Dakota steering column
95 ram cluster
B body drums
E body disc
98 jeep radiator
99 neon hvac (still fitting)
95 b3500 booster and master
Do i qualify??
67 cuda notchback body shell
What its got, either installed, or getting ready to install
74 dart V8 K frame, mounts, and spindles
74 dart floorpan
74 dart trans crossmember.
74 dart power steering box
74 dart power brake booster
74 dart V8 center link
74 dart V8 throttle cable
74 dart driveshaft
79 cordoba big brakes frt and rear
79 cordoba master cylinder
85 fifth avenue 15x7 steelies
85 fifth avenue oil filter adaptor
75 duster 4 speed floor plate
73 scamp sway bar tabbed LCAs
67 fury lll center chunk
71 dodge truck cut and narrowed 8&3/4
77 volare' A833 OD trans
Swapmeet hurst linkage
Evilbay Hurst shifter and tower
Unknown year aluminum bellhousing
Unknown year clutch fork
67 plymouth stock steering wheel
67 dart buckets (need recovering)
67 charger bucket seat side trims
69 barracuda rear seat (need recovering)
68 barracuda seat tracks
68 cuda upper header panel
78 truck 360 (block)
67 newport shock plates
68 barracuda bumper jack
67 newport V speed wiper motor n switch
68 plymouth dog dish hubcaps
68 340 exhaust manifolds
67 cuda LH fender
67 cuda reverse lights
67 cuda center trunk trim panel
68 dart vent window assembly.
28 + different vehicles not including the barracuda body shell i started with. I seperated em out. A lot of stuff came from the 74 dart i had as a parts car, so i concider that 1 car, like the cordoba, and fifth ave. Then theres repop **** i got boxes and boxes of. Reminds me of a few lines from Mad Max when they are looking at the black interceptor for the first time.
"Max" so howd you get all this together
"Barry the mechanic" Well you know Max, it was easy, a piece from here, a piece from there.
"Max" that easy ??
"Goose" youve seen it, youve heard it, and your still asking questions ?!?
"Max" when do we go for a ride !?!
Maybe over !
