74RRunner
Active Member
I'll answer any specific questions about things I may have overlooked, but if you're just going to be snarky and passive aggressive then I think we're done here.go on ahead and fill 'em in then.
And what's the parts list look like? Brand? Machinist work and itemized per what services they were asked to do?I haven't ran the numbers in a while now, but the last time I did I sat down and made me a list of everything I would need I called a couple of machine shops for the cost of machine work and the bill was around 5 grand and that was for a 318 and nothing fancy.
okay, if you want to play coy then here's the specific question: list up the receipt or the costs of the components missing. cam, lifters, push rods, gasket kit, oil pump, pump pick up, timing chain, water pump, fuel pump. and what about the heads? did you re use your intake and carb?I'll answer any specific questions about things I may have overlooked, but if you're just going to be snarky and passive aggressive then I think we're done here.
Nobody's bein snarky. Either you're willing to share a cost list or not. That's on you. You've been asked VERY specific questions about missing items. You were asked what YOUR cost was, not what something "can be had for" somewhere else. They are legitimate questions to the subject.I'll answer any specific questions about things I may have overlooked, but if you're just going to be snarky and passive aggressive then I think we're done here.
It was all name brand parts. New rings, pistons, rod and main bearings. Arp rod bolts, resized rods. Oil pump, oil pump drive, cam, lifers, matched valve springs and timing chain. Hot tank block, bore & hone with torque plates, install cam bearings and freeze plugs, turn & polish the crankshaft. Cylinder heads, hot tanked, valve job ( 3 angle). Guide work, install valve springs with correct installed height. Gasket set. Prices sure were more reasonable back then that's for sure.And what's the parts list look like? Brand? Machinist work and itemized per what services they were asked to do?
Right! And see......somehow, all the head work isn't being talked about here. Seats, guides and new valves will eat up a THOUSAND BUCKS real quick like. BAM gone. Because if the heads need guides, then purt near guaranteed they need new valves and seats, because worn guides wear valve stems and a machine shop worth its salt won't do the job without new valves. Sometimes you have to have intake seats, too. Then you're really talkin about an expensive set of iron heads......and some people do it. Then you've got all the other parts and machine work. It's not a 2500 dollar proposition anymore. Not even here and we have some affordable machine shop prices around here.Hardened valve seats ?
I don't remember what brand of parts was looked up and I didn't keep the listAll name brands.. but 0 brands listed except ARP.
I looked around and found some old notes: pistons- speed pro, rings I think were perfect circle, rod & main bearings- sealed power, cam set- comp cam 268H, oil pump - melling hv, gasket set- fel pro.All name brands.. but 0 brands listed except ARP.
oh, wow, all the parts we talk about all the time here on the forum. imagine that.I looked around and found some old notes: pistons- speed pro, rings I think were perfect circle, rod & main bearings- sealed power, cam set- comp cam 268H, oil pump - melling hv, gasket set- fel pro.
and a comp 268 on a low key stock rebuild that didn't get balanced? sure. sure. okay. cool. cool. right. riiiiigggghhhhhtttt.
love me some book time: .2 to change a battery. but also .2 to change an oil pump pick up.It would be impossible to do all that in 34 hours doing it to the level most GOOD shops do it at.
I think there are more than a few assumptions in those hours ie engine is already out and pan off?love me some book time: .2 to change a battery. but also .2 to change an oil pump pick up.
sometimes not!I think there are more than a few assumptions in those hours ie engine is already out and pan off?
That was only a planned build, I never said that it was built, haven't you ever thought something out on paper? Oh I forgot your way to smart and perfect to do that. You crack me up.oh, wow, all the parts we talk about all the time here on the forum. imagine that.
I wonder what year that is from.
Resurface a v8 head - 1hr : $9.00
I hate to disappoint you but the machine shop is still very much in business. I went through one of my file cabinets and found one of my old note books in the bottom of the cabinet. I really wish that I was as perfect as you and junkyardhero are. How is it to know that you don't make mistakes of any kind?He looked around, where he can't find anything and stumbled upon something he supposedly cooked up years ago from a machine shop that prolly isn't around anymore. I'm sure he had this quote filed in the safe under the B's
oh, so that was all a big dream? yeah, get back at us when you actually, ya know, do something. not some fantasy in your head.That was only a planned build, I never said that it was built, haven't you ever thought something out on paper? Oh I forgot your way to smart and perfect to do that. You crack me up.
bullshitI hate to disappoint you but the machine shop is still very much in business. I went through one of my file cabinets and found one of my old note books in the bottom of the cabinet. I really wish that I was as perfect as you and junkyardhero are. How is it to know that you don't make mistakes of any kind?
Your so great how come your not building engines for the street outlaw guys or busy making movies??oh, so that was all a big dream? yeah, get back at us when you actually, ya know, do something. not some fantasy in your head.
you're like that guy in highscool: yeah, i coulda made time with that gal. yeah i coulda made that catch. blah blah blah.
danimal, you don't gotta fake it to kick it amigo.
