How to change my small bolt pattern to big bolt pattern
67DodgeDart360
Delaware
Changing my Small bolt pattern to Big bolt pattern. The reason is because they have more wheel options. Please let me know the cheapest way to do this. Can I get new axles? And should I get disc breaks from a 73-76 Dart? The wheels I want are 18" 5x4.5 and the wheels I have our 18" 5x4. Any info will help. Thanks,
The cheapest way is wheel adapters.
Just remember, "cheap", "good" and "safe" are all totally different things.
Ok I'll bite. What are we looking at? The wheels you wish to put on your Mopar I presume. That blue frame musn't be whats left of your Mopar is it?
Am I seeing rear engine?
Get a hold of Doctor Diff. DoctorDiff Drivetrain Components
He has the best selection of options, and the prices are not bad. Plus help if you have issues when installing the kits. IMHO you'll spend just about the same amount of money, and a lot more time, trying to piece together something yourself.
Im going to gess that the wheel pic is just to show the size of the rim that you are leaning twards? I did a front and rear small to large bolt conversion also. I got the upper control arms from Ebay witch you will need, I beleave the calipers and disks i got at NAPA any 76 or above parts number for the dart, or duster with dicks should work, as for the larger rear drum and the Axels for my 8 3/4 391 posi i got them from Doctor Diff, the axels came with the berring already pressed on, i bought a few pices here and there and once i had it all we did the conversion. if I had to poke at a price 550 600 range.
I told you what to do in your second thread asking the same question
