Yes, going to try the engine flush. It sat for 6 weeks then showed 55psi at idle so I'm thinking it's not that bad.A better description of the gunk, gritty,grey slime greasy
Black mud or tar like.
Some idea.
Sea foam engine flush.
I wonder if there is a filter available that is full flow. No bypass. I had a chevy small block that was chock full of grey sludge. Couldnt pour oil into it.
Radiator specialties engine flush, 1200 rpm for 30 minutes and dump and fill with 5w30.
I ran a heavy truck 2 quart size filter with no bypass and changed oil a week later.
Best running 350 i ever owned.
I don't understand what you mean by "gunk", either. Have you examined closely the oil drained from the pan? Have you tried inserting a "borescope" camera into pan thru the drain plug hole? Maybe someone left a shop towel in the engine before they buttoned it up. I've seen that happen, and heard of it happening on someone else's engine. I think I'd pour clean diesel into the top and drain it out the bottom. It's super cheap, a good solvent, and yet still a lubricant. That way you could readily see what "gunk" you really have. Like I suggested before, pull the filter and blow comprested air thru the filter adapter hole. You'll hear bubbles in the diesel in the sump. If any "gunk" is in the pickup, it should be dislodged. Drain again, examine again. Cut the filter open carefully, and closely examine the contents. If there is any metal particles in the filter, you may have significant damage.Yes, going to try the engine flush. It sat for 6 weeks then showed 55psi at idle so I'm thinking it's not that bad.
With a hint of coconut..i get a whiff of it when i pour it or use the spray.Seafoam
- Pale Oil 40.00 - 60.00 %
- Naphtha (Heptane) 25.00 - 35.00 %
- IsoPropylAlcohol 10.00 - 20.00 %
Ill put a little umbrella in mine next time I crack one...With a hint of coconut..i get a whiff of it when i pour it or use the spray.
LOL, this is what I was saying about a week ago....had a rear main seal leek on my new motor. Pulled it last Saturday, replaced the rear main seal, dropped the engine back in Monday morning, reattached stuff throughout the week after work, went racing Saturday....Ain't race cars fun???
Build was in 2013. I think there was a thread back then. No thread on the rebuild, but there will be something coming once I make it back to the track.Yay! Good thing you didn't have to flush the oil pan... I'd love to see a video of your car in action btw, you have a build thread or something?
