gdizzle
Not sure which forum is best for this, so I figured gotta go where the brains are, which is of course the Early A forum
on my 66 dart, I have been removing and reinstalling the Voltage regulator like 50 times over the past 2 weeks. And now one of the holes is completely stripped. Currently I insert a piece of paperclip and then screw the screw in, but that is only good for 1x, then when I remove it I have to start all over. Any suggestions on how to deal with this? Thought about retapping the hole to next size up, but it isnt very thick so not sure how many threads I could get. Thought about getting a self-tapping screw, but since I take this on/off often I would fear the threads wouldnt hold up. Is there any sort of metal anchor designed to go in the hole permanent, then I can screw into the anchor? Maybe drywall anchor (the metal type)? How idiotic would that be?? help. p.s. ground is not a huge issue (would be nice) as I am attaching a separate ground wire from the screw to the battery ground terminal.
