Should move slightly to the discharge side, as you're drawing power from the system. You may have it wired backwards? Try turning on the headlights without starting the engine. What way does it move then?So I've just finished the wiring in my 1968 dodge dart,and wired up the amp gauge,when you turn your car on but not start it should the gauge move to the the charge side of neutral?
No, just a guess but you may have a wire set reversed.So I've just finished the wiring in my 1968 dodge dart,and wired up the amp gauge,when you turn your car on but not start it should the gauge move to the the charge side of neutral?
At fast idle, immediately after start the ammeter might show as much as 20 - 30 amps charging. It would only show that much if the battery is a little lower than normal.
In less than a minute, the current should drop toward zero as the battery charges.
Just switch the cables on the battery....easier to get to??????![]()
Yep they were backwards,all good now,and yes it goes to almost the c after starting and then goes to just above center when idling ,thanks for explaining how to read it, I have fusible links on either side under the hood,just in case something goes sideways,but it's cool having it function
OMG, that's exactly what I thought. Do NOT do that.LORD, NO!!! LOLOL PLEAUSZE don't post stuff like this, SOMEWHERE someone will read it and try it!!
