Hughes retro roller lifters and 10w30
Small Block Mopar Engine
  1. lomchivok
    lomchivok Well-Known Member
    236
    43
    Apr 10, 2016
    wa.
    Local Time:
    12:52 AM
    I've got a set of the Hughes lifters in my 408. They work just fine. Hughes recommends 10w30 oil for use with their roller lifters and that's what I'm running now. I am a big fan of castrol gtx 20/50, have ran it year round with no issues for decades in NW Washington and would like to use it again. Anyone using these lifters using any other weight oil than the recommended 10/30...your experience????
  2. MOPAROFFICIAL
    MOPAROFFICIAL Well-Known Member
    7,943
    7143
    Jun 1, 2016
    Beach
    Local Time:
    12:52 AM
    I have the solid roller version, morel makes them for people "hyd/solid"...like Hughes, maybe even exclusively now since I bought mine through Doug Herbert for less money "$280.00" ..that was 2011.
    I run 20 50w with them.... No where does morel say what oil weight to run, Hughes, once again... is full of it.
    I bet there is an un measurable difference in cold oil flow between the 2...one that makes about zero diff in lifter life, but some are dreamers and it helps them sleep at night.. regardless im sure thats their angle with that advice.
    Only 2 things with the lifters is to stay at or under 220seat/425 ish open... and keep the solid lash @ .014-.016. The 170lbs seat Hughes says is really odd and Imo overly cautious imo. What decent solid roller could you run and control, may as well stay solid.jmo
  3. IQ52
    IQ52 Well-Known Member
    2,669
    2350
    Jul 30, 2011
    Idaho
    Local Time:
    1:52 AM
    Never select your oil viscosity by what the engine requires. Only choose the oil by what gives you a warm and fuzzy feeling.
    • Like Like x 1
    • Agree Agree x 1
    • Darter6
      Darter6 Well-Known Member
      4,481
      1796
      Jan 16, 2008
      Nevada
      Local Time:
      12:52 AM
      I run 20-50 in my roller teen.5 years now still running.About 20K + miles.
    • MOPAROFFICIAL
      7,943
      7143
      Jun 1, 2016
      Beach
      Local Time:
      12:52 AM
      I drive from LA to the high desert and to the San Joaquin valley. Temps range from 40's to 115 degrees, rpms in 3800-4200 rpm cruise for 300 miles at a time. The motor is set up .0025 mains and full groove bearings.
      I'm fuzzed out.
      I did the mobil 1 5wt multi once... no thanks, I like to see higher than 15-18 psi at idle, but I don't own a dyno...so getting warm and fuzzy over 3 hp from an oil change doesn't apply to me ;)
    • lomchivok
      236
      43
      Apr 10, 2016
      wa.
      Local Time:
      12:52 AM
      That's what I figured too. Hughes probably is looking for a way out of warranty claims with the many problems people have had with their retro rollers. I was among the fortunate, mine have no operational or machining issues. I will be changing to GTX 20/50 this afternoon.
    • yellow rose
      yellow rose Overnight Sensation FABO Gold Member
      28,537
      24967
      Jun 19, 2015
      Central Washington
      Local Time:
      12:52 AM
      I have posted this before...but maybe should again.
      I want to qualify this as I haven't tested this stuff since 2008.
      Every single time I tested HRT with a 30 verses a 50, the 50 always, every time made more power. Some of that came from the fact you could turn 300-400 more RPM but most of it came from the heavier grade oils ability to resist pumping up, and more importantly, we found that lower grade oils also tend to make the lifters lose lift at lower pressure.
      Run the 20w50 and you'll be fine.
      • Like Like x 1
      • ocdart
        ocdart Inland Mopars Car Club FABO Gold Member
        9,727
        3069
        Nov 5, 2006
        North OC, SoCal
        Local Time:
        12:52 AM
        On the Callies/Morel website (www.johncalliesinc.com) they list two different part numbers for small-block mopar hydraulic roller lifters. The street version (PN 5321) doesn't show any oil limitation, but the race version (PN 6072) specifically states "Do not use oil heavier than 5W/40".
        Here's a link to the dealer list from their website: John Callies, Inc. - Dealers
        • Thanks! Thanks! x 1
        • yellow rose
          28,537
          24967
          Jun 19, 2015
          Central Washington
          Local Time:
          12:52 AM
          Is that race lifter the bushed one?
          I do know that some of the lifters have an issue getting oil to the rollers.
        • BigBlockMopar
          BigBlockMopar BigBlockMember
          1,761
          764
          May 1, 2011
          Netherlands
          Local Time:
          9:52 AM
          IQ52, you forgot the "/s" on the end. :)
        • scremn
          scremn Well-Known Member
          111
          10
          Jan 27, 2007
          Local Time:
          3:52 AM
        • IQ52
          2,669
          2350
          Jul 30, 2011
          Idaho
          Local Time:
          1:52 AM
          I really don't know what that means. Could you explain?
          • MOPAROFFICIAL
            7,943
            7143
            Jun 1, 2016
            Beach
            Local Time:
            12:52 AM
            Yeah it means you're gay for chevy...../s
          • rumblefish360
            rumblefish360 So close, yet so far away FABO Gold Member
            41,100
            12572
            Jun 21, 2005
            New York, on a Island
            Local Time:
            3:52 AM
            Oil viscosity should be tempered with temperatures outside since heavy weight oil gets really thick and can not be pumped around the engine very well soon first starting the engine.
            Run what ever makes you happy. Normally I run a 10/30 - 10/40.
            Never a issue.
          • BigBlockMopar
            1,761
            764
            May 1, 2011
            Netherlands
            Local Time:
            9:52 AM
            IQ52, it's a closing tag for 'Sarcasm-mode'.
            • IQ52
              2,669
              2350
              Jul 30, 2011
              Idaho
              Local Time:
              1:52 AM
              I need further clarification. Does this mean I'm gay and love chevies? Or.......chevies are gay and I love them?
              • Like Like x 1
              • MOPAROFFICIAL
                7,943
                7143
                Jun 1, 2016
                Beach
                Local Time:
                12:52 AM
                Lol nah I'm just razzing,10 30w reminds me sbc oil like a sum'bitch and the owners always run 10 30/40w piss.
              • BigBlockMopar
                1,761
                764
                May 1, 2011
                Netherlands
                Local Time:
                9:52 AM
                Glad I'm running 0w20 in my Dart heap :)
                • Like Like x 1
                • MOPAROFFICIAL
                  7,943
                  7143
                  Jun 1, 2016
                  Beach
                  Local Time:
                  12:52 AM
                • famous bob
                  famous bob mopar misfit
                  19,381
                  8678
                  Aug 14, 2011
                  okla
                  Local Time:
                  2:52 AM
                  ------------------------This.------------- mine requires 20w50 now, maybe 10w 40 this winter ??
                • MOPAROFFICIAL
                  7,943
                  7143
                  Jun 1, 2016
                  Beach
                  Local Time:
                  12:52 AM
                  Select by temperature! Lol
                  It's hot where I drive...
                  • Agree Agree x 1
                  • moper
                    moper FABO Gold Member FABO Gold Member
                    15,929
                    2051
                    Dec 27, 2004
                    eastern CT
                    Local Time:
                    8:52 AM
                    So it's not whatever's on sale?
                  • BigBlockMopar
                    1,761
                    764
                    May 1, 2011
                    Netherlands
                    Local Time:
                    9:52 AM
                    Well to be honest, the 0w20 full synth in above pic(s) was on sale at the time... Just $2,50 per bottle.
                    I think it takes someone man enough to pour this kind of oil in an old engine... :poke:
                  • rumblefish360
                    41,100
                    12572
                    Jun 21, 2005
                    Local Time:
                    3:52 AM
                    My son in laws Subaru BRZ sports car takes some of that water weight oil for the boxer engine.
