SCredneck
LARGE member
Wife car. 99 Durango 2wd 360. All original. 298,000 miles. Running hot. In last 2 weeks, have replaced T-stat (new 160*), fan clutch, water pump (bearings went bad). Burped system each time. Idle with cap off, pointing uphill to get air out. Is ok until stop for a few minutes. The length of 2 redlights is all it takes and temp runs up to 240 range. Will SLOWLY cool back down to 210 if keep it moving after that, but will not go lower than 210 and will QUICKLY heat back up if slow down. The length of our driveway (approx 1/8 mile rutted dirt road) is all it takes to jump from 210 back up to dangerous. I'm stumped. While running with cap off to burp system, I can tell the pump is circulating good, I can see the difference in flow well enough to know when the stat opens. I need help, PLEASE.
