My bet is on a spark issue, hook a timing light to it, when it quits, crank it and see if the timing light is pulsing, I bet you lunch it is not.
Hydraulic vs. solid lifters is not a relevant question.
Thanks for your response... We suspect carburetor issue.. We are getting fuel to carburetor, but possibly not enough fuel.cannot flood with choke, so question is cannot find replacement carburetor for industrial, so can we obtain adapter for automotive carburetor?Which parts have you replaced when you say you've "replaced the electronic ignition system"?
I don't think much of your "two seasoned heavy equipment mechanics" -- it sounds to me like they're taking random guesses and throwing random parts at the problem rather than doing proper diagnosis. You've got fuel (how do you know/where and how are you checking?) and spark (how do you know/where and how are you checking) when the engine will run...which one of them do you NOT have when it won't run (how do you know/where and how are you checking)?
It's not valves too tight -- if they're tight enough to make the engine fail to start, it would barely run (if at all) ever.
This problem is not going to be difficult to fix, but it's going to take proper diagnosis.
Didn't this problem exist before the carb job, thus prompting such?Not that someone didn't d**k w/it prior for some reason. For an engine to just flat out refuse to start warm,slantsixdan,.I wonder if that's the issue with this /6. OP said the carb was rebuilt,.maybe they did the same thing with the choke pull off??
Distributor?We have replaced the coil(2X), electronic ignition system, porcelain resistor, carburetor boiled out and adjusted, plugs and wiring...we have had two seasoned heavy equipment mechanics who have tried to solve the issue, and it appears that the engine is getting fuel and spark... If it starts and dies after ten minutes it will not restart under any conditions til the following day...we thought the coil was most likely issue and replaced with new, and when that did not resolve the issue we used a coil we know was working and still the issue is persistent... We also put in a new electric inline fuel pump... So...any ideas we might have overlooked?
THIS THREAD IS OLDER THAN SOME OF THE MEMBERS ON HERE!!
Thread's dead, baby. Thread's dead........
