XtechX
Active Member
As some of you know, I've been chasing front suspension issues (It wont align). I have some more information that might help someone diagnose whats going on. Myself and and another guy were trying to adjust the toe in on the car, we would measure with a tape from wheel to wheel and then I would drive the car back and forth and then measure again and it would be way off. We finally noticed why, the passenger wheel was cambering in when I would pull backward and then camber way out when I would pull foreward ????? I dont undersatnd how its doing it?? Everything is tight, especially the camber adjustment bolts, It just doesnt make sense!! I did take the top ball joint out because I seen it shucking a very little bit (like it wasnt tightend down all the way), It almost looks like the uca threads are abit stripped, but that isnt why its toe ing like its doing. I tightened it back up for the time being, plus Im thinking that I might get those fancy uca's with the extra caster and also the adjustable strut rods, just to eliminate possibilities. Just to bring some up to speed about the car, 68barracuda fb, all new everything in the front suspension, I didnt put it together, I bought it that way, its been about 2 months and I still cant figure it out.
Any ideas????? :banghead:
