Could be but I found these local and stock style has worked for 50 years on my stuff Car Nut
nothing a drop of blue loctite on each bolt won't prevent thoughgrade 8 might be too hard looks like 5 was oe
8 won't streach and might loosen from the vibs
Yes thank you gassernothing a drop of blue loctite on each bolt won't prevent though![]()
neil.
Thanks for bringing this thread back up, I cant believe that a FSM would make that kind of mistake in torque specs. I just checked my manual that I downloaded from MyMopar and it calls for 210 inch pounds, or 17.5 foot lbs.Bring this thread back up because.........yes you said it, my manuals (two of them ) both said 30 lbs, these are 68 and 70 Dodge B Body books, and I leared this today, yes, I should have looked farther I guess, but the drivers side is torked in all 5 after a chase on the threads and got it out with a pick , center passenger side. Flooded it with oil and it started to move with my pick, going to buy ten new bolts and remove the others incase I stressed them , now to find proper bolts..
