$950 for an aftermarket wiring harness? I AM in the right business (Telco repair) to start fixing these! I won't make it a hobby but it can be done for far less than 950. Even if you replaced every junction with the correct replacement socket, the wire is not usually the culprit, it's the splices and crimps that are at fault. 90% of your harness is probably A-OK, it's just the connectors that go bad. And you won't end up with a harness that does not follow the factory color codes. Some of you got the funds to just buy a new one, go for it. It will only save you time. And for some of us that is more valuable than money.
The condition of the old harness really depends on a lot of things. I agree, it’s usually the connections and terminals that cause problems. But sometimes that leads to other issues, like a melted bulkhead connector, or melted wires.
On my Duster I had a horn relay go nuclear. I didn’t realize the amount of damage that it did until I pulled the old harness apart, but several wires inside the harness runs had melted together. So it ruined not only the horn wires, but others as well.
And then there’s the splicing thing. The original harnesses weren’t designed for many accessories, and a lot of folks run aftermarket accessories that need power. And over the course of 50 years that means things may have been spliced in and added in ways that damaged the original harness.
Yeah, $950 is a lot for a harness, totally agree. But the AA harness is high quality, better than the factory harness ever was even new. It has more fuses, so there’s less overlap and it’s easy to troubleshoot issues. And it has provisions for all kinds of accessories- electric fuel pumps, electric fans, radio, power windows, locks, etc. So if you wanted to add an electric fuel pump it’s super easy and it’s fused, no cutting and splicing. If you add electric fans, same deal. If you add EFI, all the fused battery and accessory power is available. Just a ton of options.
Is it right for a nut and bolt 100% accurate restoration? No, it’s not. But but after tearing my 48 year old factory wire harness down to the individual wires and seeing the damaged insulation, corroded wire and terminals, scabbed in mess from who knows what past owner, and even the stuff I added to run accessories and amperage the original harness was never designed for there’s no way I’d mess with modifying an original factory harness for any significant changes.
