LovetheA's
Well I'm doing a lot of work on my 67 GTS and I'm at a point where I'm was putting in my drivers side Schumacher Tri-y to test fit. In what alternate universe does the Schumachers bolt right in a 383 4 speed 67 Dart? I realize that Schumacher says that the header needs to be modified to work in a 4 speed. That was done by accurate exhaust. They weld in about 2 inches of pipe right before the end of the collector. I mean my rusted TTI's I took out fit much better than this even with the z bar clearance trouble. It doesn't look like there is any way to make this work with the torsion bar and clutch fork in the way. By the way the headers are black because they were ceramic coated by Jet Hot. I'm open to any suggestions? What to do?
