welcome to FABO where WASG's are converted to absolute authority.Ok. Curious, are you guessing my cam just by the sound?
Round, orange.What's the balancer look like?
If I raise idle past 700-725 it really clunks when I put it into gear. Kind of uncomfortable lurch.I would like to see the plugs (in order) 1357-2468.
And raise the idle 100-150 rpms.
This is what I start with.
Then make sure all 8 are firing would be next.
Then I’d be all over that ignition timing (initial and total both)
You can screw with vacuum advance some other time.
It’s possible the really low idle and a mild cam could make a “shake” and cause a jumpy vacuum reading.
Round, orange.. Pics below
That appears to be an external balanced damper. Speaking of idle speed, what kind of difference is there between going from neutral to drive?Round, orange.. Pics below
Cone type sure grip has 2 spider gears.Sure-grip rear end or One Wheel Wonder? Will make a difference how much it will clunk when putting it into gear.
Sure-grip will have 4 spider gears taking up the slack.
Open Differential will have only 2 spider gears.
Sure grip. I’ll investigate the clunk. Thanks for all the helpSure-grip rear end or One Wheel Wonder? Will make a difference how much it will clunk when putting it into gear.
No. Nothing like that. It’s not bad really. Just want it smoother. I see a smaller cam in my future.Barks tire’s going into gear?
Feels like it might?
Slops your coffee out?
Wanna pick one?
Maybe do a short video?
No. Nothing like that. It’s not bad really. Just want it smoother. I see a smaller cam in my future.![]()
I originally posted a short video of my vacuum gauge. I’m having a low vacuum/moving needle issue. The motor came with the car with no info I so was just looking for some direction. I’ve got a path forward now with troubleshooting and will hopefully get it sorted. Thank you for the time spent.I must be getting old. I don't see the problem...............
12" vac in gear or neutral?Thank you. Is 12 inHG considered low? Or would that be fairly normal if it has a mild cam? Maybe I’ll remount the intake manifold.
He rambles off lame **** all the time. When he started talking balance right off the bat, said to myself.. where's the rotten tomatoes or hook to pull this clown off the stage..Cone type sure grip has 2 spider gears.
I have not noticed a differenceUnhook and plug the carb dist vacuum rubber line at the carb and see if the idle smooths out.
