AJ/FormS
68 Formua-S fastback clone 367/A833/GVod/3.55s
- Joined
- Jan 19, 2014
- Messages
- 26,617
- Reaction score
- 13,852
Resistance thru the PU varies a bit with temperature, but I typically see 300 +/-50 on a good one.
As to the ECUs, I have seen them bleeding goo all over the apron and still working just fine., as long as they are grounded back to the battery.
I have also seen the ballast resistor spitting out it's porcelain core, and still working fine. But they are sensitive to the the spade connectors building up resistance when not being tight enough. Once the voltage to the ECU drops below about 9volts, they can start acting up, altho I have witnessed them working just fine at 8 volts and idling.
