KindredSpirit
Pictured is the ignition switch harness in my '71 Swinger. When I bought the car the orange and two red wires were cut and not inserted in the connector, most likely due to installation of a replacement ignition switch. I see from the FSM that the orange goes into the port next to the large red wire. That leaves two open ports. The FSM shows the two red wires, which I have labeled 1 and 2. I don't know how to match these red wires to the correct positions in the connector. One port is for the key-in ignition buzzer and the remaining open port is for the headlamp buzzer relay/door open switch. Does anyone how to determine which red wire goes in which connector port?
