Manny Valencia
Hello All,
I recently had a new ignition starter switch installed which was functional after figuring out a separate reason why my 318 wasn't getting spark.
I messed around with some stuff under the dash where all the wiring was at and I am not sure if I knock something loose, but now my engine won't start!
All it does is crank without sounding like it wants to start and even more weird it cranks at the ON position, before actually turning the key all the way.
There was a point last where when I turned the key back, the engine sounded like it finally got spark for a brief moment and sounded like it wanted to start.
I tried this several times where right after ON and Before turning the key all the way that is when the engine would briefly sounded like it wanted to start.
I was told as I pull back, it sends a little voltage down the ignition wire.
Anyone have any ideas?
I tried to mess with the wiring myself and I notice a few things:
After cranking the capacitor (silver round thing) was hot.
The ignition cylinder has 2 pink cables that weren't plugged in, I am not sure what they are for?
There was an odd splice type thing going on with the yellow wire and dark blue wire, anyone have any ideas why that might be?
Here is a wiring diagram
http://www.mymopar.com/downloads/1972/72DartB.JPG
