scarlette1969
Member
Hey guys I'm working on a 69 dart /6. I've been going through the wiring system and trying to correct a bunch of wiring problems the previous owner hacked up. Nothing major just getting lights hooked back up and it went great.
My problem is my starter went out... or so i thought. It started to give a great big thump thump thump coming from the starter. I thought the solenoid was bad but then realised my voltage was low when I turned the key. So I jumped it and it would start up real quick but with a thump sound start.
I replaced the starter and still have low voltage coming in to the dash and radio. Battery is good too. So I thought I'll hot wire the car by just crossing the two wires to the starter. It worked and sounded exactly how it should.
My question is would a loose connection in the wiring at the ignition in the dash do that or what? It tries just cant do it from the key.
Thanks for the help!!!
