Hi
Does anyone have wet kit on indy tunnel ram intake? I would like to see how did you do the plumbing and nitrous/gas lines if possible.
I wanted to install one kit on my intake. With Indy tunnel ram there are injector stands that are cast in the runners, I am guessing these are for fuel injectors more than nitrous, but my plan is to use 180 degree nitrous nozzles where injectors would normally go.
I saw indy tunnel ram that had stands milled off with 90 degree nitrous nozzles, but I'm not a fan of doing it this way.
Wanted to do minimalistic plumbing close to intake like on the Indy single plane done by Wilson.
Thanks
Thanks
