that is the "stick in a bucket of cooked Quaker Oatmeal" shifter. I am hoping for input that will be a substantial improvement. might be asking too much LOL
So a couple of questions as I understand they are not much fun to rebuild.
1. How much improvement can one expect to see from a likely never rebuilt unit? (IT'S SLOPPY)
2. I believe I read somewhere about using a Hurst shifter mechanism & linkage with the Inland stick for stock appearance. Brewers offers a kit, BUT see # 4 below
3. I see Brewers has the inland mechanism rebuilt and in stock. From what I have read the most difficult part is rethreading the reverse lockout cable up through the shifter and attaching to both ends. any input ??
4.They also offer a Hurst inland conversion which is out of stock. It looks more like a make believe factory hurst mechanism without the stops and uses the inland rods which sounds a bit cheesy
5. Ideally, I'd like to replace the shifter mechanism and rods but retain the stick for appearance.
Which of the above will give the most improvement ?
Any other options/sources?
Any input on the above is much appreciated
TIA
TIA
for your input and replies. Much appreciated. I hope visit here more often when I get the time. I have owned More 340 Darts than I can remember mostly 4 spds and Swingers
. The one that got away is pictured. Sold about 1981 In San Jose Ca. last seen there about 1983 or 4. love to find it or one in the same color. Thanks again
