Inner axle seal stuck
BRog
Member
Greenwood, IN
I noticed some diff fluid leaking down backside of tire - traced it to the inner axle seal. Problem is I can't get old one out. I've tried a pry bar. I tried using the axle as some have suggested, but no luck. Everything I'm doing is just tearing up the inner part of the seal, but the seal itself hasn't moved an inch. I'm thinking someone has replaced this seal before and put some sort of adhesive on it. I need to get it out but don't want to damage anything. Any suggestions? Thanks
I bought a cheap china made slide hammer/seal puller on ebay to get mine out, seals were in sooo tight it broke the tool, but did work and only cost $14 lol
like this one?
[ame]http://cgi.ebay.com/ebaymotors/Rear-Axle-Bearing-and-Seal-Puller-Remover-Slide-Hammer-Set-1-to-2-7-8-NEW-/371050948304?pt=Motors_Automotive_Tools&hash=item56645c26d0[/ame]
Get a long section of steel water pipe and come in from the opposite side and knock it out from the other side. Course, that will require removing the center section, but it will work.
