robertodonnell
Hi All,
After reading nothing but good things, I decided to order the MP tensioner for SB Mopars, and I just wanted to check the opinion on how hard it should be to install the timing chain and gears with this installed.
Even with the lock pin in place on the tensioner's chain runner, I found I had to press back on the runner to have it clear the chain so I could fit the gearset. Is this OK? I figured that it probably is, but just wanted to check. It was nearly a 2 person job to do it. Well, me and my 4 year old boy anyway!
Gearset is a Comp 3 keyway double row unit. Oh, and when I wind the crank over by hand it doesn't bind.
Your responses are appreciated, I want to fit this engine over the weekend.
Regards,
Robert
Regards,
Robert
