Installing the classic dash for 1967 dodge dart
I have a 67 dash frame and gauge cluster that will fit the Dart. It was from a Barracuda, but the dash frame fits all A-Bodies. The gauge cluster is different from '67to '68. The speedo has a screw on cable in '67 and a snap on in '68. There are also subtle differences in the heater control openings especially where the fan speed switch is. I have both gauge sets available with 120 MPH speedo's with tripometer. The dash housing (sheet metal section) is clean but needs paint. But difficult to ship. PM me if interested.
@Jonathan Paulsen did you ever get the Classic Dash panel installed, and if so, how did it turn out? Also, which dash frame did you have, the '70 non-Rallye or the '67 Rallye? Interested for any info before making a purchase.
I used the PG Classic dash bezel and was generally please with the appearance but not with the fit. The support piece that fits on top of the bezel did not fit into the slot at the top of the bezel. I had to use a Dremmel cutoff wheel to enlarge the grove in the bezel so the plate would fit. As this is the load bearing plate for the upper screws, it has to fit tight. That was nerve wracking, but done successfully. I expect that other bezels may be better made, but there are also 30-50% more expensive. The picture below is how the finished dash looks now. I was fortunate to have scored an original tach 30 years ago from a junkyard which I installed. It replaced an Autometer tach that I put in the blank hole way back in the 1970's. Figured that one out long before FABO existed and it worked all these years.
Let me know what you want to do.
I finally got around to trying to fit the classic dash in my 69 Dart. It will need to have some dash trimmed to fit and the holes don’t line up with the holes in the dash.
That's a shame that the holes don't line up and trimming is needed. I have been looking for a documented install or video for this specific panel on the '69 dash frame but haven't had any luck. I just sent them a message to see if there is anything they can provide. It looks like they were looking for someone to document an install back in 2018. '67-'69 Dodge Dart Dash Now Available From Classic Dash - Mopar Connection Magazine | A comprehensive daily resource for Mopar enthusiast news, features and the latest Mopar tech
I like the dash itself. I don’t mind the trimming the dash too much. The holes not even close is kinda annoying . I’ll bend the dash frame and make new holes to install eventually. Dustin
Just got this dash kit in last week. Just took out my factory cluster and looks like I will need to do some cutting to make it work. No way it will work without cutting. Has anyone put this dash in yet. I ordered mine through Autometer but the dash is made by Classic Dash.
To add to that, part of the reason for doing this would be to not have to spend a fortune re-chroming original plastic pieces, does anyone know where to purchase a matching glove box cover to replace that plastic Chrome original?
Chk PG Classics, or try National Moparts.
Btw. You can buy a complete repo 68-69 GT (and a 270 /standard dash) bezel set. BUT.... If you have a 67 you would have to get your heater radio bezel re chromed / refinished
FWIW, I found out that classic Dash who actually makes the ABS housing for these gauges, also sells a glove box cover, either matte black, carbon fiber or aluminum. It also looks like they sell their housing with three options, ac, no AC or no heater controls. I might buy directly from them because while I have a 67 Dart I have 73 to 76 A/C heater controls complicating my situation. Then at least I can cut the ABS to fit my Oddball heater controls. I don't mind modifying the dash frame whether it be adding tabs and drilling out for holes in the right location. These parts seem very expensive but try getting plastic re-chromed these days and you're still stuck with a 60-year-old sweep style Speedo with a cable and idiot lights!@?
If you put up an ad I bet you can get a 67 control for cheap. Or checkout the local wrecking yard for 72??? Pickup. It uses the same 67 swing lever control
I'm using all the 73-76 A/C components except for the compressor, I don't know that I would be able to use any other controller ? All the vacuum lines etc...
I actually worked with Classic Dash on the development of this product. I furnished them a complete dash to do the design work. Yes you do have to cut the metal structure to make it work. I can post a picture of the dash showing the modifications that will have to be done. This installation isn't for the faint at heart. Since you cut your dash frame there is no going back.
#1. Using gauges that don't stick out the back very far will make it a lot easier to get in and back out.
#2. Wire it before you install it with a plug that you can unplug. It might take more than one. Plus it's going be in and out several times as you make things fit.
#3. With the thickness of the dash you will find the dash knobs won't just install like they originally did.
I'm going to have to get some pictures of the other dash where I have it stored and it is already cut out. I will have to continue this tomorrow.
That would be fantastic! I'm expecting it to be a lot of work but I think it will be worth it in the end. My Dash is out of the car and I plan on doing all the modifications on my bench.
Since your using 73 up AC might look for a 73 up dash frame that has the cut outs for the AC registers.
I think this is going to be my answer. A bit pricey but with the electric gauges and a GPS speedometer I will have awesome modern functionality without having to add gauges under the dash or on the steering column and I don't have to worry about spending stupid money on chroming old plastic. This whole build started out as a 67 GTS 383 clone but has quickly devolved into whatever the hell I want it to be LOL. Partly because I don't love all the extra trim, it's a water trap and I like the clean look that you get without some of that top trim Chrome etc. I do like the front fender mounted turn signals but once again, mine are pitted and only have one of the orange lenses and without the fender top trim they look lost on their own so I'm more and more deciding to do what ever I think is going to work out. Wait till all the OG's see what kind of seats I end up with!
