so where the two oval shaped pieces curve in, i couldnt just radious those off and blend it to the rest of the plenum?
Sell it and buy a Victor
In all the intake tests done on 383s and 440s the street dominator makes power right up with any other intake
Good intake - leave it alone.
if you have a 1" holley single hole space bolt it on. grab some moroso epoxy(or any other fuel resistant epoxy) and fill in the large openings in the intake. let it dry and smooth it out to the holley spacer. blend in the turns to the top of the runners and that should do it for you.
$400 for that, cant be worth that much
But thisis along the lines of what i was looking to do
You could just put a phenolic spacer on there and run what you like and it would be killing about 3 birds with one stone. But then there wouldn't be a thread to talk about I guess...
