victoriabc67dart
Member
this is my first post but i have used this website a ton over the last year and a bit while working on my 1967 dodge dart and doing a full swap. I had my motor bored and everything done to it as well as the heads done, during the process i was asked by my machine shop guy if i wanted to have my crankshaft balanced and change it from an externally balanced motor to an internally balanced motor. I asked about the difference between the two and decided it was a good thing to do at the time. i got my engine back and was pumped i spent alot of time and with some help pulled off swapping everything and getting the motor in and up in running with myself and a few friends. after breaking in the cam and taking it out on the highway a few times i put my insurance on it and was thinking i was ready to rock for this summer starting up. i just started taking it for some spins earlier this week and had my carb tweaked up and it was running great, then yesterday i pick my friend up to go for a ride. we had got to a stop sign and i have it in first (it's a 3 speed 727) and start to drive i get it up to about 2500 and go to shift into 2nd and hopefully get a little chirp but instead around the same time as shifting i hear the worst noise ever, sounded like a metal spoon being banged around inside a steel pot. i immediately pull over and shut it off my friend an i notice a nice stream of oil running out from the rear of the pan i look underneath the car and it is pissing oil out of a big hole and a little hole that has been bunched through the pan by something i automatically think i threw a rod. i got the oil pan off this morning and to my surprise there is no rod inside it but there is instead a pile of shrapnel pieces of the oil pump and what was left of the pick up along with a socket shaped piece of metal. i called a friend of mine with much more experience then myself and he instantly looked in the oil pan and pulled out that socket shaped piece of metal. after telling him i have had my crank internally balanced we go under to inspect the damage that had been done and we see the spot on the crank where that piece of metal which was what was the weight for balancing the crank had broken off and hit the oil pump breaking it, sending the pump and pick up then into the crank and being smashed and twisted into a million pieces and also damaging two of the pistons. i know am pretty pissed and also upset that i have spent so much time in getting all of this going and finally i can drive it and this happen has anyone had this happen before and what should i say to the guy who balanced the crank? any input would be appreciated , sorry for the long post but i gotta vent lol
