Inverse radius cam lobe
It's not hard on valvetrains.
I run one. Pulls hard beyond adv. power band. Efficient.
With that much change in momentum on the lifter, youll probably need some very good springs.
You need LESS spring
1 inverse radius can give more reliability at the same area under the curve
or 2 the same reliability (springs etc)with more area
the ir gives the designer time to set the valve down easy with less chance of bounce
or 3 more effection duratio and area ith same seat timing
for street pick 1
